Dent in fuel line! Can anyone do a FI flare?
Old Sep 28, 2000 | 12:32 AM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Axle/Gears: 9" with 4.10s
Well nobody is perfect.
I put a bit of a bend in my pick-up line.
I tested the fuel pressure at WOT and it does not drop, but it may with more mods or when I spray.
Does anyone now who could put flare on a line that will seal a FI system. I do not think, or care to risk, doing this with a double flare tool.
Thanks!!
Michael Graeber
My Garage
1)83 Z-28 T-Top: Full cage, 9" w/ lad.bars, Midwest Engine Tech 406sbc,Strip Dominator, Demon Carb, Phase VI Chevy Bowtie heads, .630" Crower roller set-up, 1 3/4 coated Hookers 3" true dual exhaust th400, fuel cell & still not running
2)89 Formula WS-6 305 TPI Auto For the road: minor motor, more suspension stuff. MODS
Old Sep 28, 2000 | 07:20 PM
graebz28's Avatar
Car: 83 Z28
Engine: 406
TOP
Old Sep 28, 2000 | 07:37 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
I am glad that you know there is a difference. Most people don't. Some GM dealerships have the tool to do so. Also, there are some places that do this. There are a couple of places here in Savannah that make custom lines like that. If it is a small one, you could just order a new one from a dealer, or get them from http://thirdgenparts.com
If you live in Southeastern US, check us out!
South East Thirdgen
"I used to have a handle on life, but then I used it as a plunger and broke it" -The Wave
ASE Master Tech + L1
Savannah, GA
'87 Trans Am-K&N,Cold air induction, SSM SFC, Boxed LCAs, 8mm Accel wires, Flowmaster, 16" GTA rims.
'97 Bonneville SSE
Old Sep 28, 2000 | 07:54 PM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Thanks brother!
I'll try some of the local dealerships here.
This way I can remove the fuel pump w/o dropping the tank.
Thanks again!
Old Sep 29, 2000 | 06:21 PM
monte-ss's Avatar
Car: 87 Monte Carlo SS
Engine: 89 IROC 350 TPI
Transmission: 700R4 rebuilt w/TCI kit
Axle/Gears: 9" from 57 ranchero unsure gears.
I used double flare's on mine and have had no probs in it at all been there 2+ years I need to redo it cause of too many bends but still works just fine and holds pressure
'87 Monte Carlo SS,with '89 IROC 350,700 trans, blew up 3.73 posi stuck with crappy 2.73's neeed gears! hooker headers, flow's 2 1/2" exhaust true dualls
Old Sep 29, 2000 | 06:34 PM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Monte,
Did you use an O ring on it?
I'm using it to go from a hard line to one of the high press rubber line like the one that attached to the fuel rail.
Did you use a d flare to go hard to hard line or hard to soft?
Old Sep 29, 2000 | 07:47 PM
Guest
Guest
Posts: n/a
I did part of the first step of the double flare to bubble the end of the hard line, then cut the metal end off the rubber line and just clamped it on there. Been that way for 2 years. I also did some double flares here and there. The only disadvantage I can see to a double flare is the orifice size necking down in the fitting, that inevitably happens. If you went to an AN fitting setup that wouldnt be a problem. A double flare can more than handle the pressure of FI, same goes for the AN stuff. You are only running about 50psi so really there isnt much pressure as far as fittings like that are concerned.
I dont know of anyone who has the equipment to do the saginaw flare (which I assume is the FI flare you are talking about). Im sure its out there, just havent seen it.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
