Car runs like crap, i wanna kill it.
Old Jun 5, 2007 | 06:42 PM
Chris`s85Z28's Avatar
Car: 1985 Z28
Engine: LG4 305 with a few modds
Ok i have a 1990 Pontiac Firebird GTA and can not for the life of me get it to run right.
i did intake gaskets this winter so i also replaced the plugs, wires, cap and rotor oh and the O2 sensor, when i did the intake gaskets the intake was leaking anti freeze and the O2 was bad so was the EGR, so i fixed the EGR it was just carboned up so i cleaned it and it worked fine, now i put AC Delco plugs wires cap and rotor on and found out Delco wires are the biggest pile of crap made b4 this i`d recommed them to anyone but now no way.
heres what it does, at idle i can make it run really smooth by retarding the timming but it`s slowler then my moms neon, if i advance it, it`ll run fast down the street but sounds horrible at idle like it`s missing like mad. i don`t have a timming gun so i`m setting timming by ear and i did unplug the tan wire.
this is what i know, the car at idle only puts out 12 inchs of vacuum it`s suppost to put out 18 so it`s real low on vacuum, my O2 sensor maybe bad the oil temp says -39 so thats bad and i have to replace the wires AGAIN. i havn`t done a compression check yet.
and if anyone could put a pic up of the vacuum lines on the right rear of the engine, (350 TPI) that would be great.
this year so far i`ve put brakes on the front still need to do the back a tranny, intake gaskets and rear tires about 1000 bucks worth of stuff, i`m getting so sick of this car, she`s lucky she`s pretty LOL, i had a offer of 4500 last year i shoulda took it.
so if anyone has any ideas on whats wrong with my car i`d love to hear them.
Old Jun 5, 2007 | 11:05 PM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
Re: Car runs like crap, i wanna kill it.
Get a timing light and set the timing right. Next you have a vacuum leak somewhere, aka rough idle. And get the sensors fixed. The ECM probably is not going into closed loop due to faulty sensor readings.
Also buy a Chilton’s, will give you all the vacuum diagrams, and lists of trouble codes exec. And they are only 20$
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
kyleb24
Aug 15, 2015 08:24 AM
hokis
Aug 9, 2015 03:57 PM
Kaweh
Aug 9, 2015 02:54 PM
