What do codes 33 and 42 mean??
Old Oct 2, 2000 | 02:01 AM
Transformer's Avatar
Ok I got some codes now but I dont know how to interpret them. What do I need to look for. Any experieneced TPI hot rodders or techs out there know what this is.
88 GTA 5.7
88GTA 5.7(under construction) ATI Procharger,58mmTB,ported plenum,SLP runners,Edelbrock HI-FLO base.ported heads,1.5RR,210/220/480 compcam,AFPR,SLP1 3/4 headers,3.70 gears,Eibach drag launch,Lakewood LCA`s, Nitto drag radials.
Old Oct 2, 2000 | 08:42 AM
Bill91Z
Guest
Posts: n/a
33 means you have a high voltage at the MAF (a low vacuum reading). 42 usually means a problem with the EST or an ignition problem. This info can be seen in the FAQ section of this site.
-Bill
-=ICON Motorsports=-
Boston Chapter
91Z28, (in progress) 3.8L, TE63-1 turbo, MSD50lb injectors, Hemco upper, ported TTA heads, 62MM TB, Red's XP fuel pump, 3.73s, vigilante (stall to be determined)
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
