SuperRam VS TPI
Old Oct 5, 2000 | 08:50 AM
Godti's Avatar
Car: Trans AM
Engine: 305 TBI
Transmission: 5spd
SuperRam VS TPI
When you are going for high horsepower and torque, can you keep the stock TPI or do you wanna switch to a super ram?? What if you are trying to build a 383 stroker, can you use a stock tpi or do you wanna go with the super ram??
And what are AFR 190s????
Godti
'89 Trans Am (Red)
305 TBI 5spd
Old Oct 5, 2000 | 08:54 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
If you are aiming at high HP and high torque go for superram/big mouth intake.....
AFR190= Air Flow Reasearch cylinder heads 190 cc port volume
GTA -89:Free flow muffler,dual 3" HF cats, Edelbrock headers, Vette heads, 1.52 RR 7/16, ZZ-9 cam, Big Mouth, AS&M LTB, ported plenum, 52 TB, MSD 6AL, TPIS level V prom, Mod .MAF, Superior shift-kit and some minor mods. and more to come!
http://www.itv.se/tacs/members_cars/m279/m279.html (Swedish Trans Am Club)
Old Oct 5, 2000 | 09:05 AM
Godti's Avatar
Car: Trans AM
Engine: 305 TBI
Transmission: 5spd
Where can I get some info one a TPiS super ram?? whats the price??
Same for the AFR 190, where can I get some more info, and pricing??
Godti
'89 Trans Am (Red)
305 TBI 5spd
Old Oct 5, 2000 | 10:54 AM
kwikgta's Avatar
The SuperRam was designed by John Lingenfelter and is produced by Accel.
The MiniRam comes from TPIS.
92 GTA(only 226 made)ort matched sportsman heads with 2.05 valves,64 cc,milled .015,.028 head gaskets,port matched Accel runners,port matched plenum,port matched edelbrock intake,flow matched injectors,jet hot headers and 2.5" mandrel bent exhaust,Flowmaster muffler,underdrive pulleys,slp cam,1.6 rockers,slp cold air induction,52mm throttlebody,performance resource custom chip,Dyna module,Screamin Demon coil,Accel 8.8 wires,Bosch platinum plugs,timing at 10 degrees,tb bypass,relocated map sensor,shift kit,Fairbanks billet servo,pump vane kit & 2400 stall,Torque converter lockup switch,3.42 posi with welded axle tubes,Zexel Torsen HD diff.,Summit rearend girdle,solid pinion spacer,& alloy axles.Boxed panhard bar,lakewood lca's & edelbrock strut tower brace,Jeg's torque arm,Jegs welded in subframe connecters.Performance friction pads,turbo slotted front rotors,stainless braid brake lines.Roh ZT 17x8.5 front wheels with 255/40ZR/17 tires. 17x9.5 rear wheels with 275/40ZR/17's on the street.Hoosier 26x9.5 slicks on the strip.
Old Oct 5, 2000 | 03:38 PM
Godti's Avatar
Car: Trans AM
Engine: 305 TBI
Transmission: 5spd
Ok, is the mini-ram as good, better or worse?? What does every one recommend??
Godti
'89 Trans Am (Red)
305 TBI 5spd
Old Oct 5, 2000 | 07:50 PM
Steve91Z28 L98's Avatar
Car: 1991 Camaro Z28
The miniram is the way to go, I think. You will get more top end horsepower out of it. You will sacrifice some low end torque to the Super Ram but it is well worth it in my opinion. The miniram costs around $900 from TPIS and then you need to fabricate your own fuel rails or but them from TPIS for around $300. The Super Ram consists of three parts, just like the stock TPI setup. It has an upper plenum which is much larger than stock and has runners that are much shorter than stock but alot larger in diameter. The Base is just like a stock base with much larger ports. The miniram is one piece. You are going to spend around the same amount of money for both. Maybe a little less for the Super Ram but the Miniram is worth the extra price. I know someone with a miniram on their '88 Corvette and it flies. Look at these sites: www.tpis.com and www.lingenfelter.com
1991 Z28 - 350 TPI, T56, Centerforce Dual Friction clutch, ported plenum & runners, AFPR, Holley Annihilator ignition box and wires, Hooker shorty headers w/o AIR, no cats, Flowmaster muffler, homeade ram-air, SSM subframe connectors, Steve Spohn adjustable torque arm and T56 crossmember
Old Oct 6, 2000 | 01:25 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
I would not buy a miniram for a 305 cui engine, Its designed for 350 or bigger engines. If you are going for a 383 the miniram is the way to go.....( even if I'm not going to buy one..)
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
