TBI to TPI fuel pump and lines
Old Oct 11, 2000 | 08:31 AM
CR89WS6's Avatar
I just picked up a complete TPI system for my 89 Formula for $150. It has everthing. NOt sure if it's SD or MAF. Anyways, I need to know if a new fuel pump is needed, if so would an inline be the way to go? Sould I find a TPI pump? And Do I really have to replace the existing lines? Any other bits of change over advice is welcomed!!!!
89 Formula 305 TBI
Flowmaster, 1/2 in. spacer,lowered 3 in, 84' ram air, performer tbi intake,hypertech chip, ultimate TBI mods
Old Oct 12, 2000 | 10:48 AM
RCR's Avatar
RCR
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
I did your swap a couple of years ago. You need to find out what year your TPI is, so you know whether it's SD or MAF. Checking out the wiring harness should give that away if you have it. I switched to the TPI fuel pump for my swap. I wish I had used a better/bigger pump. I used the existing fuel lines, because unless someone can show me different part numbers, I'd doubt GM would build these with different lines.
If you have any questions, let me know.
Bob '89 Formula CC350
Charter Member of the Elusive Great Lakes Crew
My car's homepage
92camaroJoe
Jul 29, 2023 07:57 PM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
