crate motor
Old Jun 11, 2007 | 07:17 PM
avengersteve's Avatar
Car: 1988 firbird formula
Engine: 5.7l pony eater
Axle/Gears: 4.10
crate motor
hey all, im looking to get a direct replacement cratemotor for my 88 TA which one would i be looking for? i want as close to the stock 5.7 as possible. maybe a gm performace frfom summitt?
Old Jun 13, 2007 | 01:26 PM
Detroit_Z28's Avatar
Car: 91 Z28
Engine: L98 350
Transmission: TH350
Re: crate motor
There isn't an exact replacement motor for our cars. An 88 has the newer intake pattern, roller cam, center bolt valve covers and 1 piece rear main in it, which makes crate motors kind of scarce. The ZZ4 crate motor is the closest, it's basically a L98 corvette motor with the aluminum heads, and a different cam. However, it doesn't have egr provision in the heads, which means you must switch to a vette style intake and weld a pipe in the exhaust manifold, or delete egr from the prom. In fact not many aftermarket heads are meant for our cars. Might be easiest to find a roller short block and get L98 heads for it. Then all your existing stuff works.
theshackle
Sep 17, 2020 08:26 AM
theshackle
Mar 5, 2017 06:37 PM
italiano67
Dec 11, 2016 09:21 AM
Steve78LT
Feb 24, 2016 12:15 AM
masonta
Aug 31, 2015 10:14 PM
