HELP!!! won't start no crank signal
Old Jun 13, 2007 | 02:26 PM
89N10GTA's Avatar
Car: 1989 GTA
Engine: 355 with Super Ram
Axle/Gears: 3.73 10 bolt with a True-trac
i'm lost i have an 89 gta 5.7L as everyone knows L98 tpi. long long story short i have no crank signal. i have replaced ECM and ING. module. with the scan tool hooked up (when it reads) it's doesn't see rpm durning cranking. i have checked all the wiring and no opens or bad grounds. i replaced EMC because with a test light when i put power to term C in 4 prong ING. module still get no signal. when i spray carb cleaner down it's throat it will start and run just not great. i'm hoping somebody can help.
Thank you
Paul
Old Jun 13, 2007 | 02:31 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: HELP!!! won't start no crank signal
Have you checked the pickup coil in the distributor?
Old Jun 13, 2007 | 02:35 PM
89N10GTA's Avatar
Car: 1989 GTA
i have and it test good and will read rpm when it is running.
Old Jun 13, 2007 | 02:37 PM
t5camaro's Avatar
Car: 1991 Camaro
Engine: 355TPI
How did you check the pickup coil? did you put the voltmeter on AC?
Old Jun 13, 2007 | 02:42 PM
89N10GTA's Avatar
Car: 1989 GTA
i had it on ohms and alldata says 500-1500 ohms is right. now if it was bad would i see rpm when the car is running?
Caspar
Jun 19, 2016 11:19 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
Fronzizzle
Aug 9, 2015 01:15 PM
