LOUD VIOLENT SUCKING SOUND!!HELP!!
Old Oct 15, 2000 | 02:18 AM
FormulaGod's Avatar
HELP!! I got a loud violent sucking sound coming from my Elelbrock baseplate region. I put spray everywhere, and cant seem to pinpoint it. Is it the IAC, or something else? Its a 1988 formula w/FULL mods. Still have the stock chip though.. Thanks in advance!!
"Ever notice how imports sound like weedwackers"
Old Oct 15, 2000 | 10:20 AM
Blade's Avatar
Get a piece of hose... put it your hear and snoop around the engine with the other end. It helps a lot to pinpoint noises
92 Z28 L98 350
Ported and polished heads, ported stock TPI base, ported plenum, Comp Cams XR270HR-10 cam (lift .495/.502 duration 218/224 lobe separation 110), Edelbrock TES headers, LT4 valve springs, Crane AFPR, Flowmaster catback with LT1 style tips, MSD coil & wires...
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
Old Oct 15, 2000 | 10:29 AM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
Check your power brake booster line ti the plenum, maybe it came off or is leaking.
1988 Formula 5L/5sp 3.45 gears, SLP cold air kit, MAS gutted, TPIS air foil, TPIS AFPR, MAC headers, Mac under drive pulleys, MAC cat back, Relocated MAT.
Best ET street tires 13.85
Best 60 FT street tires 1.930
Best MPH street tires 99.29
Old Oct 18, 2000 | 05:45 PM
Blade's Avatar
Are you sure it's the base plate ? On mine it was the IAC that was stuck closed and it was making a VERY violent sucking sound. Sounded like I had a supercharger in there or something... LOL
Old Oct 18, 2000 | 11:37 PM
Greg90iroc's Avatar
my car also makes a violent sucking sound that started right after i put the edelbrock throttle body on the IAC works fine it is just the 52mm throttle body. if i put my finger over the hole to the IAC circit and wait for a minuet then release my car screams up to 3000 rpm and the sucking sound is so loud it hurts your ears.
90 iroc l98
last season best corected 13.62 @102
mods
full exhaust, AFPR, pulley, jet stage 1 chip, billet servo, 52mm throttle body and a few other little things.
Old Oct 19, 2000 | 02:31 AM
IROCKZE's Avatar
Car: 85 Mercedes 500SEL
Engine: 5.0 DOHC
Make sure the vacuum hose is on your fuel pressure regulator. I left mine off and got that sucking/screeching sound too.
85 IROC,5.0 TPI,T-Tops,fully loaded,black with red Lear-Siegler "Camaro" interior,Decal Delete,91 Bose stereo,Stage 2 Fastchip,AFPR,TB Airfoil,K&Ns,March pulleys,Alum. Driveshaft,92 police version 700r4
"The Devil drives a Camaro"
Pac J
May 17, 2020 10:44 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
wanext
Oct 6, 2015 12:18 AM
loud91rs
Oct 5, 2015 10:05 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
