Charcoal can-Purpose?
Old Oct 17, 2000 | 05:53 PM
85ZZ4TPI's Avatar
Can I eliminate it? Im not running emissions.......
Old Oct 17, 2000 | 06:50 PM
MikeC.86Roc's Avatar
I would like to know the same thing. I am also eliminating mine and I know it won't effect the way my car runs. What I do want to know is where should I vent the gas tank to if the canister is junked?
Old Oct 18, 2000 | 10:48 AM
rich1034's Avatar
I just left my gas vent open and haven't smelled any fumes yet. I yanked it all out, and didn't notice a difference at all, except a much cleaner looking engine compartment.
Old Oct 18, 2000 | 01:02 PM
RP1987GTA's Avatar
the canister is there for a couple purposes:reduce hydrocarbons vented to the atmosphere,ie helps for a cleaner enviroment....plus it helps fuel economy at part throttle by burning the stored hydrocarbons.This is why the feds are getting involved in state emission testing.Most stock cars with emissions run WORSE without the emission controls and get poorer fuel economy ...by the way venting those hydrocarbons into the air ..puts um right in yer lungs
87GTA,350,Auto,MAF screens removed,195 thermostat,cold start injector UNPLUGED,K&N,modified air intake,ADSchip,3:73s,3inch cat back Flowmaster single outlet,TPS.54,Bosch Plat plugs,base timing 6BTDC,22 MPG and runs like a bear,Bilstiens in the rear....,don't let yer meat loaf
[This message has been edited by RP1987GTA (edited October 18, 2000).]
Old Oct 19, 2000 | 03:42 PM
85ZZ4TPI's Avatar
Then just cap the vacume lines that are leftover and vent the vapor tube to the ground?
skinny z
Carburetors
Sep 29, 2015 11:25 PM
Racerx974
Sep 19, 2015 10:16 AM
TBRays98
Sep 6, 2015 05:05 PM
BurlyChev
Aug 16, 2015 09:08 PM
Mister_Johnny99
Interior Parts Wanted
Aug 14, 2015 12:59 PM
