Fuel Pressure too high (80psi)
Old Jun 15, 2007 | 09:54 AM
wiggin's Avatar
Car: 89 IROC-Z
Engine: 383 stroker
Transmission: WC T-5
Axle/Gears: 2.77
So i put a new high flow Walbro fuel pump in, but now my AFR doesnt seem to be able to get the pressure below 80psi now. Just put a new bbk pressure regulator on and the screw is all the way out. Anyone have the same problem??
Old Jun 20, 2007 | 10:53 AM
shocker89bird's Avatar
Car: 89 ws6
Engine: 355 afr195, hsr,gmpp cam, hs rr,
Transmission: t-5
Axle/Gears: 3.08
Re: Fuel Pressure too high (80psi)
Well the best thing to do is start with the basic stuff like blowing out the fuel lines to make sure there is not a blockage in them causing a pressure rise. You can disconnect the fuel lines before they meet the tank and near the steering colomn under the hood. Best to have two people so one person can plug there finger over the other. i would spray carb cleaner in there as well. These cars are getting old so possibilities of build up in the lines is much greater. Even in the fuel rails there could be blockage. This may not slove the issue but helps narrow down the possibilties. Could just be a bad regulator.
Old Jun 20, 2007 | 08:51 PM
Fast92RS's Avatar
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
Sounds like you may have pinched the return line.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
