Is this 13's material?
Old Oct 22, 2000 | 08:01 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I am at 14.2@98 Will the Edelbrock Intake ,AS&M Runners ,Fast Chip, and BFG Drag Radials get me a 13.99999999?
89 FORMULA 350 Edelbrock Cat-Back March Pulleys
Accel Cap ,Super Coil SLP Airfoil K&N Filter 180 stat , Fan Switch
Taylor 8mm Spiral Pro,TB Bypass ,Energy Sus bushings ,Hotchkis STB ,MSD 6AL ,Edelbrock TES's ,Hi Flo Cat ,Crane AFPR ,Shiftkit w/Hurst lockup ,1/4 time 14.2@98
Old Oct 22, 2000 | 08:42 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
If you are 14.2, then just a higher stall TC like a Vigilante will sneak you into the 13s easily.
Old Oct 22, 2000 | 09:37 PM
IrocManiac's Avatar
You would be comfortably inside the 13's with that setup.
TPI 305,
Gutted airboxes,
gutted MAF,
K&N filters,
Corvette Servo.
14.9@93mph
"Speed kills, wanna live forever, drive a Ford."
Old Oct 22, 2000 | 11:00 PM
Dan87IROC-Z's Avatar
There are plenty of things you can do. Cam, 1.6 RRs, maybe port your TPI plenum, port and ploish your heads. My choice would be the cam.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: Edelbrock TES 1 5/8" Headers, Hooker Aerochamber Cat-Back System, Performance Resource Chip with 160* Thermostat, Accel Ignition Components, K&N Filters, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET : 14.32 @ 97.7mph
(corrected for elevation)
Old Oct 23, 2000 | 07:32 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
I'm leaving the heads and cam alone. Hell the Magnum TPI went 13.5 with heads cam and everything. That sucks. if i can squezze out a 13.8 fooling around 3 grand aint worth .3 secs
Old Oct 23, 2000 | 07:23 PM
Car: Death Mobile
Engine: 666 c.i.
Then go the TC route...it is relatively easy to do (though messy) and it REALLY should be done once you change the cam and heads anyways. So jump the gun, and do the TC first.. and then when you get your next "Need For Speed" urge, then you can go the cam and head route and have a TC already waiting for you.
Old Oct 24, 2000 | 01:14 PM
Greg90iroc's Avatar
if you ask me the Magnum TPI was a failure. they spent all that money throwing parts at the car and they did not even try to go faster with tuneing. Tuneing is the biggest single improvment you can do for your car other than a power adder. tuneing of your car can ammount for as much as 1/2 a second or more in the 1/4 mile. When i went from 7 deg of timing to 10 deg and jumped the fuel pressure to 50 psi i slowed down 4 tenths at the track. octain boster gave me 3 tenths back and when i droped the timing back to 7.5 deg and the fuel pressure to 47 psi i went 2 tenths faster than the previous best run of the day. These are minor adjustments that made a huge diffrence at the track. The moral of the story is that you can probly get to 13's with your current setup if you tune it to make max power. 13's are not hard to get from an l98 car.
Mkos1980 you have every mod i had and the base when i ran a 13.6 you just need to coax that extra bit out of your engine. That and you need to leave the line harder.
90 iroc l98
last season best corected 13.62 @102
mods
full exhaust, AFPR, pulley, jet stage 1 chip, billet servo, 52mm throttle body and a few other little things.
MrPackstin
Oct 25, 2017 08:09 PM
no green
Mar 3, 2016 05:19 PM
1Aauto
Sponsored Vendors
Nov 23, 2015 02:17 PM
Wife'sCar
Sep 5, 2015 08:58 AM
Golfvette
Aug 24, 2015 06:35 PM
