MiniRam 350... i need a little help in picking parts
Old Oct 24, 2000 | 04:27 PM
UnderDogRS's Avatar
350 4 - Bolt Main L31 Shortblock
TF 23* heads
SVO #24 injectors
TPIS MiniRam II
1.5 Roller Rockers
Accel DFI
ok, i need a cam, higher stall Tq converter,
i have 2.42(?? i think??) gears now, and would like to keep the top speed and some kind of mileage(not as important as top speed). i will be swaping the open rearend for a slp posi next summer/fall. but i hope to be putting the miniram 350 in, in the spring. what cam/Tq conveter would be the "best" for this setup??
Thanks,
RS
(A.K.A FireBird88)
AOL SN: Zander0710
1992 Camaro RS 25th anniversary edition Adopted Feb,14 2000
Mods:
14x3 Open element w/ K&N filter, MSD GM blaster Coil and 8.5 SC wires, AFPR, 60psi. Fuel Pressure gauge, 3-Row Al rad. , 180* t-stat, Hooker 1 5/8 headers, 3" Catco cat, 3" Hooker Aero Chamber cat-back, "Ultimate TBI" mods
Old Oct 25, 2000 | 12:50 AM
airdeano's Avatar
underdog,
not to undermind your thinking, but 2.42??
you wont have enough torque to carry the car to 2800rpm. and with 2.42 torque is what youll have to have to keep the car 4-4500rpm in fourth to get topend.
i went from a 2.59 to a 3.07 gained 300rpm top end, accelleration, throttle response, and lost 1mpg. and in corvettes id wished a dana36 3.33 and id probably be even happier.
for a stall 2500rpm street 3000rpm strip
cam: 550/219/112lsa
because of the torque loss gears will be necessary 3.40 or 3.70
the miniram is air volume not air speed.
itll go 6000rpm if the underside is matched.
heads afr 195-210
so a $1100 manifold going to cost you $4000...
just some things ive run into and others have too...
airdeano
Below Average J
Members Camaros
23
Nov 18, 2015 10:03 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
