I need everones help for a final projec at school.
Old Oct 24, 2000 | 09:54 AM
Kyle F's Avatar
I am going to compile a hand guid for modifying Thirdgen TPI Cars for a final prject in my technical writing class. I am doing everything from basic mods to full blown low 13 sec street racer. This includes everything from suspension to motor. I am quite familiar with this but I need to know what tech articles will be good to use and if I have premission to use them. I especially need info on brakes and suspension. I have som mag articles from like HPP CHP GMHTP, sorry for the acronyms just didn't want to type everything out. I also have info from SLP and TPIS. When I get this done it will be atleast 20 pages, I am figureing around 40, but anyways I will probably submit it on here also. I will make another post asking for permisson to use the tech articls or anyother info I found on here.
86 Trans Am 355 TPI Rebuilt 700R4 with Corvette servo, modified valve body, and a B&M Torque Converter (2000 rpm stall w/ lock up), 87 350 block bored .30 with new crank, bearings, rings, and magnafluxed rods. Reworked 305 heads with 3-angle valve job. Added in the rebuild was an SLP TPI cam, BBK 58mm Throttle Body,SVO 24# injectors,MSD 6A, Hypertech Power Coil, 1.5 Crane roller tipped rocker arms, SLP Intake Runners and Port matching in upper intake including fully ported plenum, TPIS adjustable fuel pressure regulator @ 46psi, Hooker shorty style headers w/ Thermotech heat wrapping, Custom 3” exhaust with Flowmaster muffler and chrome quad tips, Hypertech Thermomaster Computer chip, K&N open element cone filter on modified MAF per TPIS specs, MSD Wires, removal of A/C hardware and a 1LE firewall cover installed. Also there has been a PST front suspension kit with Hotchkis strut tower brace
http://geocities.com/SunsetStrip/Garage/9548/kyle.html
Kills:
95 Talon TSI, 96 Probe GT, 91 T/A L98, 89 RS, 86 Mustang GT, 88 Mustang LX 5.0, 92 Thunderbird V8. couple or ricers that I think were Civics or Preludes not sure what year, 95 Celica GT-S, 94 Chevy 1/4 ton 350, one of those NASCAR F150's
Old Oct 24, 2000 | 11:11 AM
kwikgta's Avatar
Feel free to use mine:Beefing the 7.625" 10 bolt"!
92 GTA(only 226 made)ort matched sportsman heads with 2.05 valves,64 cc,milled .015,.028 head gaskets,port matched Accel runners,port matched plenum,port matched edelbrock intake,flow matched injectors,jet hot headers and 2.5" mandrel bent exhaust,Flowmaster muffler,underdrive pulleys,slp cam,1.6 rockers,slp cold air induction,52mm throttlebody,performance resource custom chip,Dyna module,Screamin Demon coil,Accel 8.8 wires,Bosch platinum plugs,timing at 10 degrees,tb bypass,relocated map sensor,shift kit,Fairbanks billet servo,pump vane kit & 2400 stall,Torque converter lockup switch,3.42 posi with welded axle tubes,Zexel Torsen HD diff.,Summit rearend girdle,solid pinion spacer,& alloy axles.Boxed panhard bar,lakewood lca's & edelbrock strut tower brace,Jeg's torque arm,Jegs welded in subframe connecters.Performance friction pads,turbo slotted front rotors,stainless braid brake lines.Roh ZT 17x8.5 front wheels with 255/40ZR/17 tires. 17x9.5 rear wheels with 275/40ZR/17's on the street.Hoosier 26x9.5 slicks on the strip.
Old Oct 25, 2000 | 11:30 AM
Kyle F's Avatar
Thank you kwikgta
Old Oct 25, 2000 | 06:55 PM
JETHROIROC's Avatar
Buy the book "How to Tune and Modify Your Camaro: 1982-1998", a friend of mine has my copy so I don't remember the author. Get on Barnes and Noble's website and order that sucker. It covers Suspension, Brakes, Chassis, Engine, Exhaust, etc. Hope this helps, it's a pretty good book.
Rocket-Doc
Nov 14, 2015 02:08 PM
Antips16
Oct 30, 2015 06:42 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
