not going into closed loop
Old Jun 20, 2007 | 05:04 PM
LoneStar666's Avatar
Car: 2005 Pontiac GTO
Engine: 364ci LS2
Transmission: 6 speed
Axle/Gears: 3.46
car will stay in open loop when started even at operating temperature, until the car is shut off and then restarted... it will be in closed loop right when i start the car again
does anyone have any clue what would cause this?
Old Jun 21, 2007 | 12:35 AM
1TUF92Z's Avatar
Car: 92Z28,91Z28,91Z281LE,95ZR-1,08Z06
Engine: 406, 350, 305, 350, 427
Transmission: auto, auto, 5-speed, 6spd, 6 spd
Axle/Gears: all stock
Re: not going into closed loop
how do you know it's in OL still? Do you have a scanner hoop up to it? If you have, then check CTS for the computer if it's sensding the right voltage to the ECM.
Old Jun 21, 2007 | 07:05 PM
Engine: 364ci LS2
Axle/Gears: 3.46
well the car idles at 1000rpm pretty much until the car gets to operating temp and then drops down to 600-700rpm...
the car will stay at 1000rpm even when at operating temp now and ill turn the car off and then back on, and it idles 300rpm lower
edit: also, if the car is already at operating temperature and has been sitting for a little while it will automatically go into closed loop after a few seconds
Old Jun 21, 2007 | 08:55 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
There is a method to see if the car is in open/closed loop by using the ALDL port.
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Pac J
May 17, 2020 10:44 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
