Surging and Stalling- No Codes
Old Jun 22, 2007 | 06:10 PM
guitargod's Avatar
89 Formula 350, the car intermittently surges no matter if im just idling or driving, the engine check light also flashes when this happens...when slowing down to a stop sometimes the rpms dip below 500 and the car stalls. I can mostly start the car right back but sometimes when i do it just dies again. I have no codes being thrown at this time. I set the TPS (which is new)at .54 volts today which didnt help. I have new spark plugs and wires, new distributor, ignition coil, and O2 sensor. I've checked for vacuum leaks and so far have found none. College right around the corner, please help
Old Jun 23, 2007 | 07:30 AM
FearThisGTA's Avatar
Car: 1991 TRANS AM GTA
Engine: 5.7L TPI
Axle/Gears: 3.23 Posi
Re: Surging and Stalling- No Codes
IMO, it sounds like a vac leak. hth
Old Jun 23, 2007 | 07:50 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Yeah sounds a bit like a vaccuum leak . I had that on my 89 305 tpi . I had a split hose in front of the engine ... wouldn't hold an idle . but if I kept my foot into it she would run still . Was a bit laggy in throttly response aswell .
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
