Question about TPI and hood clearance
Old Oct 29, 2000 | 08:37 PM
JRoy91RS's Avatar
Car: 91 RS Convertible
Engine: 355
Axle/Gears: 2.73 peg leg
I'm about to do the TPI swap in my RS. I've had a 350 built up. I was wondering if my stock RS hood will sit high enough to clear the plenum. It looks like it's not going to work. Will it? If not, can anyone suggest a cheap hood that I can use in the meantime?
Old Oct 29, 2000 | 09:47 PM
rondubbs's Avatar
rs is a type of camaro,, camaros came with tpi.. i dont think tpi camaros had a different hood than yours. it should fit under there. you said its "built up",, im assuming you mean cam, heads, etc. unless you hava a huge blower under there, the tpi system will fit.
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
