Injector Ohm
Old Jun 24, 2007 | 09:18 PM
LoneStar666's Avatar
Car: 2005 Pontiac GTO
Engine: 364ci LS2
Transmission: 6 speed
Axle/Gears: 3.46
Injector Ohm
i ohm'd my injectors and they were all 15.4-15.7, is that too low? i searched around on the forums and the threads i found said 16.5+ was good.... ?
Old Jun 25, 2007 | 10:38 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Injector Ohm
Was that with the engine cold or hot? That's a good reading, either way. But to be sure, ohm them again when the engine is hot. Sometimes heat will cause one that is marginal to fail, but then it will read correct when its cold.
Old Jun 25, 2007 | 04:05 PM
Shamble's Avatar
Car: IROCZ
Engine: LB9
Axle/Gears: posi
Re: Injector Ohm
That seems about average, I had a few injectors running at 4 & 5, which was obviously bad....
Old Jun 28, 2007 | 07:15 AM
Engine: 364ci LS2
Axle/Gears: 3.46
Re: Injector Ohm
yeah this was with the car @ operating temperature when i ohmed them
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
