Make it so.
Make it so.
Would it be worth doing? I know a welding professor and I'm sure he could weld aluminum,so my question is......If I cut open the inside of my stock runners and had him weld them together in the middle to make homade siamiesed runners would it be benificial?
$300 bucks is pricey when compared to $20 for his welding.So should I save up for SLP runners or fire up the welder?
88 black gta
tb coolant bypass
gutted maf
gutted air boxes
no cats or smog
700r with a snior citizen discount
bald tires
88 black gta
tb coolant bypass
gutted maf
gutted air boxes
no cats or smog
bald tires
A 350 with a ZZ4 cam and 1.6 RR is a good combo for what you want to do, IMHO.
It is a good idea, maybe I'll do it too.
Let us know how it works out.
89 IROC 350 Auto
TRUE DUAL Exhaust
Edelbrock Performer Aluminum Heads
ZZ9 Cam
TPIS Level 5 Chip
14.01 @ 97.0mph with 2.77's gears
89 IROC 350 Auto
TRUE DUAL Exhaust
ZZ9 Cam
TPIS Level 5 Chip
The SLP runners are not only siamesed they are also a larger prot. I port matched my plenum to match them and I had to enlarge the openings on the plenum not only just the center section that is removed on the SLPs Also dont forget to port match tha gaskets. I think, speakinf from an engineers point of view, if you dont remove that you are just causing more turbulance going into the runners and actually reducing flow.
86 Trans Am 355 TPI Rebuilt 700R4 with Corvette servo, modified valve body, and a B&M Torque Converter (2000 rpm stall w/ lock up), 87 350 block bored .30 with new crank, bearings, rings, and magnafluxed rods. Reworked 305 heads with 3-angle valve job. Added in the rebuild was an SLP TPI cam, BBK 58mm Throttle Body,SVO 24# injectors,MSD 6A, Hypertech Power Coil, 1.5 Crane roller tipped rocker arms, SLP Intake Runners and Port matching in upper intake including fully ported plenum, TPIS adjustable fuel pressure regulator @ 46psi, Hooker shorty style headers w/ Thermotech heat wrapping, Custom 3” exhaust with Flowmaster muffler and chrome quad tips, Hypertech Thermomaster Computer chip, K&N open element cone filter on modified MAF per TPIS specs, MSD Wires, removal of A/C hardware and a 1LE firewall cover installed. Also there has been a PST front suspension kit with Hotchkis strut tower brace
http://geocities.com/SunsetStrip/Garage/9548/kyle.html
Kills:
95 Talon TSI, 96 Probe GT, 91 T/A L98, 89 RS, 86 Mustang GT, 88 Mustang LX 5.0, 92 Thunderbird V8. couple or ricers that I think were Civics or Preludes not sure what year, 95 Celica GT-S, 94 Chevy 1/4 ton 350, one of those NASCAR F150's
Kills:
hectre13
Dec 11, 2023 08:14 AM
