manifold center bolts
Old Nov 2, 2000 | 03:11 PM
Leroy808's Avatar
i put a TPI on my 2nd gen camaro. it has a new crate engine in it. the engine must have come with different year heads because the 4 center bolts did not match up. i did not want to change out the heads so i just ground out the bolt holes on the manifold so it would fit. i have had no problems with it so far but im planing on changing out my manifold to a higher performance one. are there any that i can get where i will not have to grind out the olt holes again? any help would be great.
Old Nov 2, 2000 | 05:14 PM
Wraith's Avatar
Edelbrock has what you are looking for. Go to the Next Generation web site and look for it. Edelbrock has 2 types of manifulds 1) is for the newer type heads and 2) is for the older type heads. Good luck
1991 Trans Am GTA, Accel 300+ ignition, underdrive pulleys, AFPR, Accel SuperRam (ported out), Edelbrock lower intake (ported out), BBK 58mm TB, TFS 23* heads, SLP 1 3/4 headers, SLP 3" cat back (no cat), CompCam .495/.502 lift, Kenny Bell strut tower brace, lower frame brace, Jeg's SFC, Lakewood trailing arms and panhard rod
Pony's can run, but bird can fly
1987 Buick Turbo-T
1977 Chevy Blazer 4X4
Old Nov 2, 2000 | 05:30 PM
rich1034's Avatar
Or get an 85 tpi baseplate, they work on old heads.
Old Nov 2, 2000 | 09:34 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Most high performance bases are setup to accept both bolt patterns.
If you live in Southeastern US, check us out!
South East Thirdgen
"I used to have a handle on life, but then I used it as a plunger and broke it" -The Wave
ASE Master Tech + L1
Savannah, GA
'87 Trans Am-K&N,Cold air induction, SSM SFC, Boxed LCAs, 8mm Accel wires, Flowmaster, 16" GTA rims.
'97 Bonneville SSE
deracer
Apr 11, 2016 12:04 AM
Hawkeye1980
Aug 31, 2015 07:09 AM
theurge
Aug 21, 2015 12:46 PM
blackd-out z28
Aug 15, 2015 08:18 PM
