305 tpi question
Old Jun 29, 2007 | 10:55 PM
186irocz's Avatar
305 tpi question
I was working on getting all my a/c out of the car tonight so i can replace everything with new stuff, an i decided to look at all my spark plugs, #3 had some raw fuel on it? what would cause that, i already eliminated the cold start injector for fuel related problems, are my heads going now ? or is it something like a leacky injector, the car runs very well! and has tuns of power, so im wondering why spark plug #3 would have been wet?
Old Jun 29, 2007 | 11:33 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: 305 tpi question
Easiest diagnosis is a bad #3 injector. Do a resistance check on each injector using an ohm meter. You should see between 13-16 ohms when hot. Anything less and its probably bad.
Old Jun 30, 2007 | 01:48 PM
186irocz's Avatar
Awsome ill do that tomaro, still have all my ac ripped out, waiting on the new parts to install, so i have a/c on my trip to detroit for the f body meet .
gta90
Sep 15, 2015 04:00 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
