TPI wiring harness for '90 speed density
Old Jul 1, 2007 | 04:38 AM
RPOL98's Avatar
Car: 90 IROC
Engine: 5.7L TPI
Axle/Gears: 9-bolt BW
looking at the aftermarket TPI wiring harnesses to retrofit a 1990 speed density system into an older car. any advice? recommendations?
I see that Painless Wiring sells a harness, Howell also. not sure if there are others.
I intend to use the 7730 ECM since I already have the chip-burning capability for that.
Old Jul 1, 2007 | 07:53 AM
S10Wildside's Avatar
Re: TPI wiring harness for '90 speed density
I can help you with your project. We frequenty build new TPI harnesses for custom vehicles. If you're interested, please email me at mike@eficonnection.com.
Please include:
- desired length from ECM to back of engine
- desired length from ECM to diagnostic port
- whether torque converter lockup (700R4) is required
- number of electric fans
- 3 wire heated O2 sensor or single wire O2 sensor
Thank you
Mike
EFI Connection
Old Jul 1, 2007 | 05:56 PM
scuzz's Avatar
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
I've used a TPI harness and OBDII harness from eficonnection(S10Wildside). Quality pieces. Trust his work.
Ron
Old Jul 8, 2007 | 01:17 AM
billydonn's Avatar
Car: 66 c-10 stepside
Transmission: TKO 600
I just used a Street & Performance harness to put speed density TPI in my 66 truck and thought it was very well engineered. Not cheap though.
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Steve78LT
Feb 24, 2016 12:15 AM
Reddeath210
Oct 6, 2015 08:20 AM
86Base
Aug 8, 2015 01:34 PM
