I need your help once again...
Old Nov 11, 2000 | 02:58 PM
Kyle F's Avatar
I need pictures of aftermarket strut tower braces, suspesion equipment, customized camaros/firebirds, any other modifications you have pictures of, I need this for visuals for my final projecvt in english. THis is also a chance to get a pic of you car in a manual with you name on it. Please if you know whos car it is tell me so I can give sredit where credit is do. Like I said any pics of the final outcome of modification to any part of a TPI car would be excellant
86 Trans Am 355 TPI Rebuilt 700R4 with Corvette servo, modified valve body, and a B&M Torque Converter (2000 rpm stall w/ lock up), 87 350 block bored .30 with new crank, bearings, rings, and magnafluxed rods. Reworked 305 heads with 3-angle valve job. Added in the rebuild was an SLP TPI cam, BBK 58mm Throttle Body,SVO 24# injectors,MSD 6A, Hypertech Power Coil, 1.5 Crane roller tipped rocker arms, SLP Intake Runners and Port matching in upper intake including fully ported plenum, TPIS adjustable fuel pressure regulator @ 46psi, Hooker shorty style headers w/ Thermotech heat wrapping, Custom 3” exhaust with Flowmaster muffler and chrome quad tips, Hypertech Thermomaster Computer chip, K&N open element cone filter on modified MAF per TPIS specs, MSD Wires, removal of A/C hardware and a 1LE firewall cover installed. Also there has been a PST front suspension kit with Hotchkis strut tower brace
http://geocities.com/SunsetStrip/Garage/9548/kyle.html
Kills:
95 Talon TSI, 96 Probe GT, 91 T/A L98, 89 RS, 86 Mustang GT, 88 Mustang LX 5.0, 92 Thunderbird V8. couple or ricers that I think were Civics or Preludes not sure what year, 95 Celica GT-S, 94 Chevy 1/4 ton 350, one of those NASCAR F150's
Old Nov 11, 2000 | 05:34 PM
rondubbs's Avatar
this is my engine,.... if you use the pic, make sure you spell my last name correct
Old Nov 13, 2000 | 09:40 AM
Kyle F's Avatar
Thanks Ron and I will use your pic for the strut tower and yes I will double check your name
J.C. Denton
Sep 8, 2015 05:35 PM
InfinityShade
Aug 22, 2015 08:00 PM
Xenodrgn
Aug 1, 2002 05:12 PM
BigMike92Z
May 1, 2002 10:00 PM
