WTF fuel pressure drop?
Old Nov 10, 2000 | 05:44 PM
theformula's Avatar
I had my pressure set at 42 pounds (hose on)and 50psi hose off. I let the car sit in my garage for a week while I worked on it. Today when I started it up today the fuel pressure was reading 35 pounds hose on. (probably 42 hose off).
The car was A LOT faster. I'm sure of it, it wasnt my imagination.
The fuel pressure was at 35 pounds from when the engine was cold.....all the way to operating temp. Could the computer of returned itself to stock setting while it was being stored for a week? THe afpr is brand new, and so is the spring and diaphram.
CAR RUNS GREAT!
ps: i have a digital fp gauge installed in my car.
'92 Formula
305 TPI
Mods: SLP headers,SLP catback,SLP air foil,ported plenum,Crane AFPR (50psi),MSD6AL,homemade cold air,K&Ns,3:73s,JET fan switch, Macewen white face gauges...ZZ9 cam is coming!
[This message has been edited by theformula (edited November 10, 2000).]
Old Nov 13, 2000 | 04:31 AM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
Always check fuel pressure with the hose off. Engine vacuum varies acording to many things including state of engine tune, temperature & other things. Different vacuum will cause different fuel pressures. Pull the vacuum hose to the regulator to remove that variable and check The pressure then. That is the only way to get reliable, repeatable results.
  • 355 cid
  • AFR heads
  • Arizona Speed & Marine hydraulic roller cam w/ AFR hydra-rev kit
  • modified SLP runners
  • TRW forged pistons/ceramic coated
  • fully balanced
  • Edelbrock headers/ceramic coated
  • SLP cat-back
  • Paxton supercharger
  • Nitrous Express nitrous oxide
My IROC-Z
EFI Performance Club on Yahoo
Old Nov 13, 2000 | 11:02 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
This indicates that 50psi (hose off) was far too high for you engine and you were running overly rich.
I do notice that you mention "cold". If by that, you meant the air temperature was noticeably colder, then that will also produce more power.
Yesterday, I took a drive up to the Rockies where the temperature was -10C (about 15*F). Even with the altitude, the engine had a lot more passing power than it normally does at sea level just because of the colder air.
Old Nov 13, 2000 | 11:27 AM
theformula's Avatar
I never said the air was cold, but damn your read my mind. It is cooler here. The FP just keeps acting really funny. The car is fast as ***** though. It just keeps pulling. It also may be due to my computer slightly re-adjusting to my ported plenum and cold air.
It can take weeks for the stock PROM to re-adjust sometimes (TPIS insider hints).
'92 Formula
305 TPI 5speed
1LE package
Mods: SLP headers,SLP catback,SLP air foil,ported plenum,Crane AFPR (42psi),MSD6AL,homemade cold air,K&Ns,3:73s,JET fan switch, Macewen white face gauges...ZZ9 cam (i still have to install it )
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
