Install miniram on milled AFR 195 heads. Double intake gasket?? what gasket to use.
The heads on this 383 are stage 3 ported, HUGE ports. And we are installed a brand new miniram on it. The gaskets that came with miniram arent even close to being big enough. What gaskets to use? plus it appears the heads are milled because the intake ports are kinda low. Is there any double thick gaskets we could use?
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Wayquick,
Sounds to me like whoever milled your heads did not correct the intake face of the heads. You should ONLY have to use standard thickness intake gaskets. If you find that you have to use anything but standard gaskets (1204's, 1205, etc) then you have a problem with the heads themselves. I seriously doubt that the MiniRam is off. Sounds to me like they didn't correct your intake face on the heads.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's after installing Hooker LT Headers and reducing weight.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Tim
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Jan 9, 2020 08:29 PM
86IROC112
Aug 17, 2015 02:00 PM
