Which wire?
Old Nov 16, 2000 | 12:18 PM
KS91Z28's Avatar
Which wire?
I was trying to follow the directions that were posted out here for adjusting the TPS, but it just talks about making jumpers between the TPS and the connector and reading the voltage. There are 3 wires, which wires am I supposed to be reading? No matter which wires I checked, I never got any readings even close to the suggested settings. Also, when I was trying to adjust the IAC, I put a jumper between A and B. When I did this, one of the cooling fans came on and I could hear something clicking up around the throttle body. WTF!
Old Nov 16, 2000 | 03:30 PM
rondubbs's Avatar
for the tps, check the upper 2 wires. make sure the key is turned on,, for this you dont need to jump the ALDL.
the fans should come on when you jump A and B for the IAC, the clickin near the TB is probably the IAC, since it is under the TB.
Old Nov 16, 2000 | 03:41 PM
KS91Z28's Avatar
Is the IAC supposed to be doin that?
Old Nov 17, 2000 | 10:26 AM
Blade's Avatar
Yeah
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
