real quick question
Old Jul 7, 2007 | 11:23 AM
jjlabinski's Avatar
Car: 84 firebird T/A
Engine: shinny 350
Transmission: slush box L65
Axle/Gears: Torsen "3.73"
real quick question
does the prom's initial timing get added to the initial base timing?
if I set my base timing at 8 and the chip is burned to have 10 at start up does that give me 18 degrees advance at engine start?
thx
jeff
Old Jul 8, 2007 | 09:09 AM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
Re: real quick question
no, they should be set the same. it's just a reference for the ECM, as in let's it know what the timing is supposed to be set to.
In your example you'd be 2 degrees retarded across the whole curve because the ECM thinks the base timing is at 10* when mechnically it's @ 8*
Old Jul 12, 2007 | 07:18 PM
jjlabinski's Avatar
Engine: shinny 350
what if my base timing is set to 14? Is this bad?
thx
jeff
Old Jul 12, 2007 | 07:51 PM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
if your prom is still set to to stock, then you have 6*( if the stock is 8* ) across the whole curve. People do this a lot, but it's not really the right way to go about it. It might not want that at some RPMs. Best way is to start tuning the curve with making a custom prom.
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
