Here we go finnally!
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
Hey guys,
Finnally i am getting around to figuring out my rough running tpi issue.
And ive narrowed it down to fuel injectors, Or a chewed cam
So, Ive decided im going to do the cam, timing chain lifters and 1.5's ( or just stock for a little tiny bit)
And new gaskets all around.
Next weekend im going to take apart the car, and pull the cam out of it.
Now, I want to put a cam on it that will make more power then stock, not kill my gas mileage and is computer friendy. and if i could get a little Lope rumble in the idle id love it
Part numbers, or cams u've had in a roller Tpi Suggestions and opinions please have some input!
Relard had a nice cam, but i believe it was a flat tappet
thanks guys!
thanks guys!
Car: 1991 TRANS AM GTA
Engine: 5.7L TPI
Axle/Gears: 3.23 Posi
Re: Here we go finnally!
SHould be a roller cam, I do believe. Unless someone has swapped it out before you got it. IMO, I would do either the LT1 cam or the ZZ4. I did the LT1, but now I wish I had done the ZZ4 cam.
Car: 92Z28, 99SS, 83Z28 & 86GTA
Engine: 421, LS1, 327Turbo & 383
Transmission: T-56, 4L60E, T5 & 4L60
Axle/Gears: 4:10, 3:42, 2:73 & 3:27
Personaly I like this one in a near stock TPI
http://www.compperformancegroupstore...Category_Code=
XR264HR #08-501-8
Friend of mine has it in his 89 Iroc, works great
XR264HR #08-501-8
Axle/Gears: 3.23's
thanks for the rec. ive decided to go with the zz4, because i can get it at work at employee price ( 200 bucks) and lifters and a timing chain
customblackbird
May 4, 2026 08:10 PM
