TPI bolt removal issues????????
Old Jul 8, 2007 | 06:03 PM
Giovannetti's Avatar
What is the best way to get out the star bolts in the runners b/c mine are stripped? And the ones that are having issues also dont have a kit if tool access to them? thanks again guys.
Old Jul 8, 2007 | 06:41 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
Re: TPI bolt removal issues????????
I am sure they are stripped because you or someone else used the wrong torx bit or used an allenhead which some times works.
Try to use one size up and beat it in with a hammer then loosen. If not then some vise grips.
Old Jul 8, 2007 | 07:04 PM
elcam84's Avatar
I see allot of stripped Torx screws. It's often caused by cheap torx drivers. The cheap ones have rounded corners to make htem easier to get into the bolt. What happens is you have very little surface area touching and it's very easy to strip it out.
I take and grind the face of the cheapies flat so they grab better.
If you can't get them out try using a lefthanded drill bit.
Old Jul 10, 2007 | 09:50 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
often you can grind a slot into the front of the bolt and use a very large slotted screwdriver (or similar impliment) to extract them.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
NBrehm
Aug 25, 2015 11:49 PM
Sanjay
Aug 12, 2015 03:41 PM
3rdgenparts
Aug 8, 2015 07:09 PM
