o2 sensor questions
Old Jul 9, 2007 | 05:43 PM
mild84's Avatar
Car: 1984 z28
Engine: 6.0
Transmission: glide
Axle/Gears: 3.50 9"
o2 sensor questions
First off, I bought an 85' z28 with a 305 tpi in it. it has 122k on the clock. It runs good, but its not getting great fuel mileage. So I've decided to start doing some of the maintains work on it. I'm starting with the fuel filter and the o2 sensor. Question 1. When I change the o2, do I need to unhook the battery to clear the cumputer? it has no ses light on, but not sure if the new o2 would through it off. Also, is there any thing else you guys would recomend to a little better mileage? Thanks for any help.
Old Jul 9, 2007 | 06:36 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: o2 sensor questions
What kind of mileage are you getting?
Old Jul 9, 2007 | 08:23 PM
mild84's Avatar
Car: 1984 z28
Engine: 6.0
Transmission: glide
Axle/Gears: 3.50 9"
about 12 in town :O
And I don't even hot rod it!!
Old Jul 10, 2007 | 05:10 PM
mild84's Avatar
Car: 1984 z28
Engine: 6.0
Transmission: glide
Axle/Gears: 3.50 9"
Anybody???
Old Jul 10, 2007 | 05:39 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
you won't throw any codes because the computer isn't reading anything when it is off, also to help increase gas mileage just try basic tune-up stuff along with the o2 sensor.
Old Jul 11, 2007 | 12:35 PM
LoneStar666's Avatar
Car: 2005 Pontiac GTO
Engine: 364ci LS2
Transmission: 6 speed
Axle/Gears: 3.46
replace all of the following, for all you know this can take a second off your 1/4 because its all oe:
Spark Plugs, Spark Plug wires, Ignition Module, Distributor Cap and Rotor, Ignition Coil.... replace all of that and youll be sure to have a very noticeable difference.
EDIT: also, make sure your timing and fuel pressure are where they should be at... 6*btdc and 42psi is stock, you really dont need much more than that... although 10* and 45-48psi wouldnt hurt.
Frozer!!!
Jan 19, 2024 04:55 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Caspar
Jun 19, 2016 11:19 PM
redmaroz
Aug 16, 2015 11:40 PM
squiggy2
Aug 9, 2015 09:30 PM
