bigger injectors doesnt mean more hp?
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
right? I mean my stock injectors r just fine with what I have in my sig? Also, I know theres a tech section for this but what r some other mods i can do besides the ones stated in the articles?
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
Re: bigger injectors doesnt mean more hp?
You are 100% correct. Unless you are doing major engine modifications, Stock injectors will work most of the time. If you plan on running large modifications on your engine, The MAF system should also be removed and goto MAP instead also. N20 can be run on MAF or MAP, providing your not going crazy on upgrades, Like Heads, Cam etc etc...
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
I may buy a cam later down the road but that would be way later. My intent is just to get my whole intake ported right now. Would that make me have to redo my prom or what?
