Intermittent Surging and Stalling
Old Jul 10, 2007 | 06:51 PM
guitargod's Avatar
I've been having this problem for a while now, and its starting to get annoying. I've changed parts that could have been the problem which for a while seemed to fix it, but now and then the problem returns. The car seems to surge up and down and the engine light flashes, and other times when going to a stop the car stalls. No codes are being thrown. Other times the car drives perfectly fine. I know it says with most intermittent problems it is usually a bad or maybe loose connection or wire but if any one knows which would be the most likely wires to check thoroughly would be appreciated
Old Jul 11, 2007 | 12:41 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: Intermittent Surging and Stalling
It could be that the fuel pump is failing. I would hook a fuel pressure gauge to the fuel rail and see if the pressure jumps.
darwinprice
17
Oct 11, 2015 11:51 PM
Reid Fleming
Oct 10, 2015 09:56 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
lanceflame44
Sep 25, 2015 12:28 PM
