high idle
Old Nov 11, 2000 | 01:30 PM
88FormulaWS6's Avatar
high idle
took out my car the other night. out of nowhere the idle was at 1500 rpms. it was like this for 30 minutes. then finally it came down to 1200 rpms. but the car wont go lower then that. the car usually idles 750-800 rpms. any ideas??? it rained hard the other night maybe a sensor got wet?? any help would surely appreciate. also i disconnected the battery for 20 minutes and let the computer reset thought that might help...it didnt.
88 Firebird Formula WS6
305 TPI 5 speed
B&m Ripper shifter
MSD Blaster coil
TPIS airfoil
Hypertech fan switch
TPIS 170 degree thermostat
3 inch flowmaster exhaust
alt +crank pulleys
15.084 @ 92.41 mph ALL RACING MODIFICATIONS PERFORMED BY JOHN-OOTZ RACING INC.
Old Nov 11, 2000 | 05:38 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
I have the same problem and I have seen others post this with little suggestions.
This seems to be a popular program and we need everyone's help to clear it. Anyone have this high idle while driving and what fixed it???????/
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Trick Flow Heads, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Dynomax Cat-back, Serpentine belt setup, Dual IROC Fans.
http://www.sethirdgen.org/octride.htm
Old Nov 30, 2000 | 01:23 AM
zroc's Avatar
Car: 87 IROC
Engine: LB9 for the moment
I have an 89 t/a 5.0 tpi and every once in a while like if the temp drops or there is moisture in the air the throttle sticks open just a bit... when it happens to you next time leave it running pop the hood and see if it is stuck open a little...
zroc
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCtometal
Sep 2, 2015 02:01 PM
