Fuel pressure????
Old Nov 28, 2000 | 09:46 PM
speed88's Avatar
Car: 1988 Trans Am GTA
Engine: 383
Fuel pressure????
Those of you who have fuel pressure regulators on L98's, could you post what you fuel is set at and what gains you noticed.
Thanx!
88 GTA
L98 350
700R4
3:27 axle
MODS,
Edelbrock TES headers, 2.5" straight pipe, Flowmaster 80 series, K&N filter, Accel 8.8mm wires, Bosch Platinum plugs, Wells cap and rotor button, Wells ignition module, MAF screens removed, Hypertech TB air foil, Thermomaster stage II chip, 180* Powerstat, Hypertech cool fan switch, B&M shift kit, B&M power clutch pack, B&M servo, GM fuel filter.
Veiw my car at:
http://www.members.tripod.com/~btessier
[This message has been edited by speed88 (edited November 28, 2000).]
Old Nov 28, 2000 | 09:54 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
My freind runs 50 psi in his stock 89 350 and noticed some torque.
Old Nov 29, 2000 | 12:16 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
50 psi....
Cant say what I gained...I did the most of my mods at the same time....Havent tried to adjust it cause it works fine as it is....
GTA -89:Free flow muffler,dual 3" HF cats, Edelbrock headers, Vette heads, 1.52 RR 7/16, ZZ-9 cam, Big Mouth, AS&M LTB, ported plenum, 52 TB, MSD 6AL, TPIS level V prom, Mod .MAF, Superior shift-kit and some minor mods. and more to come!
http://www.itv.se/tacs/members_cars/m279/m279.html (Swedish Trans Am Club)
Old Nov 29, 2000 | 04:47 AM
F22Raptor's Avatar
I had mine one time at about 60, but I didn't know I had to plug the little hose; don't know what it really was. I must tell you that my car seems to like a LOT of pressure
'88 GTA 350
Headers, catback, free mods, Xtreme energy cam, and intake pieces
13.51@104.27, but can run better as it is.
New 2100-2300 RPM converter is in. Hoping for 13.30 or better.
Old Nov 30, 2000 | 11:32 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
look in my signature.
I just now corrected it for the fuel pressure.
'87 L98 TPI IROCZ, AFR190 heads, 3.70 gears, ZZ9 cam, 2400 Art Carr TC, SLP 1 3/4" headers, SLP cat-back, no cat, no AC, no MAF screens, Accel manifold base & SuperRam, Edelbrock double roller timing chain, MSD ext coil & distributor, trans cooler, 52mm TB with airfoil, TB coolant bypass, AFPR(58psi), K&N filters, Hotchkis lowering springs, Car-Pro custom chip, Lay Ind. ram air kit, 265/45R16 Kumho V700 tires.
ET 13.39sec @ 107.21mph
'90 Eagle Talon AWD, no rust thru 9 winters
'99 Camaro SS, red, 6-spd, T-tops, Mcleod clutch, Pro 5.0 shifter, MAF processor, Direct Flow airlid, K&N filter.
313.7Hp & 320.6ft-lbf, ET 13.55sec @ 105.1mph
next mod: 4.10 rear gears
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
