balancing of performance parts help!
Old Nov 26, 2000 | 03:20 PM
blowen90ta's Avatar
everyone talks of the perfect balance for awesome results.so what do i need to do to optimize the performance of what i have?right now i am running a stock bottom end(27000mi)350 tpi,edelbrock manifold,ported plenum, stock runners,stock tb,afr 190 heads,slp 1-3/4 headers and catback exaust,stock cam(i'm shure this is bad but they really suck to change)msd 6al-btm set to 1 degree per psi boost and a paxton supercharger that puts out 6psi@5000 rpm---my tranny is stock along with my converter.am going to be installing 3.42 gears in place of the 3.23's this winter along with a new posi unit.also stepping up to 30lb injecters and a custom prom hopefully by me-with tunercat,programmer and the prom board.
any cam recomandations?
ps this car is most used as a weekend cruser not a drag racer so please keep that in mind.
thanks in advance for your input
pete
1990 Trans Am,350 TPI(L98),WS6suspension ,bridgestone RE71's /245/45/zr16
paxton supercharger, alston sfc's,msd 6AL-BTM,
8.5 superconductor wires SLP 1-3/4 headers,duel cats,3"slp exaust, lakewood LCA's,T.B.Bypass
160 degree stat,alum driveshaft,fiberglass wing, secret mods
"if you cant win fair CHEAT"
Old Nov 26, 2000 | 08:56 PM
Greg's Avatar
Car: 89 Formula T-Top
Engine: 388 MiniramII
With a supercharger you could definetly benefit with a nicer cam. I don't know how much punishment a stock bottem end can take with a supercharger though. You might just want to wait. A stock bottom end has a lot of compression for a supercharger also, so that should be lowered if you get a rebuild. I think larger runners would better fit the plenum and intake you have right now though.
'89 Formula 383 TPI
Old Dec 1, 2000 | 01:24 PM
blowen90ta's Avatar
thanks greg--but when i put the afr heads on i actually raised the comp ratio to 10-1 and with the higher efficancy of the aluminun heads everything seems fine.seems that is because of the low boost level and the water injection that all is ok.
anyone else?--thinking that maybe 30 lb svo injecters are too big maybe i should go with 24's ?
Old Dec 1, 2000 | 03:27 PM
chevyboy07 91's Avatar
You can handle 450 horse if you got fair mileage on it. As always, you might want to save the street beatings & kickdowns for the track and the occasional punk.
Hope it helps
Alex (AKA chevyboy) '91 RS 327 stroker, trans-go shift kit>> manual valve body, cat-delete, MSD (ignition, coil, 2-step, timing retard/ advance),Flowmaster, complete Edelbrock suspension including shocks, struts and lowering springs. CRAGAR drag wheels. Lowered 2.25" in front and 1.5" in rear....Best E/T 12.84 @109 mph...(got spray?)plus more!!
italiano67
Dec 11, 2016 09:21 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
