MAF vs. Speed Density
Old Jul 12, 2007 | 02:14 PM
ChampionN84's Avatar
Car: 91 Camaro Z28
I have heard different stories about the benefits of both.
What about mods to your engine, which is more acceptable to mods MAF or S.D.?
Anyone ever run into issues with modifying your vehicle
Old Jul 12, 2007 | 02:50 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: MAF vs. Speed Density
Most important benefits I'd say are:
- MAF system does not care about minor mods you make - it reads the ACTUAL air flowing through the engine (whereas a MAP system has to calculate the airflow from the intake air pressure)
- MAP sensor cannot be "maxed out" if you increase airflow - but the MAF sensor can (and then you need to find a way to make your computer guess what the actual airflow is) - and of course, a MAP sensor costs 10% of MAF
Hope this helps a bit.
Lou
Old Jul 12, 2007 | 02:52 PM
onfire's Avatar
Car: 88 Formula 350
Engine: 5----->.7 or so they say
Transmission: seven hundred with a remainder of 4
Axle/Gears: 9 bolt 3.27
ChampionN84,
These are both good methods. They will both need fine tuning to get everything running just right. Now the Mass Air Flow meter is less troublesome when it comes to adapting to engine mods vs the speed density method. If you don't want to fine tune your chip then I would go with MAF. When you have engine mods the sd setup will demand a tune out of you to drive her properly. They both have their + and - just depends on what you want to deal with.
Rabi C.
Old Jul 12, 2007 | 04:03 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Please
I just responded to three different threads on this topic in the last three weeks. You can find all my answers there.
BumpaD82
Feb 26, 2016 02:57 PM
Nick McCardle
Sep 10, 2015 08:36 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
