fuel rails for Super Ram
Old Dec 2, 2000 | 12:59 AM
RoadRacer's Avatar
I've got a Super Ram that's going in a project car and I need a pair of fuel rails for it. What years will work and are most desirable (i.e. flow the most fuel)? Also, where can I get a set for a good price (cheap!)? Used is ok.
Thanks,
Don
Old Dec 2, 2000 | 06:50 PM
irocz's Avatar
Car: '87 IROC-Z
Engine: 406 Superram/DFI
Transmission: Auto BTE 3000 conv
You use the stock tpi fuel rails. All years are pretty much the same (corvette rails are different I think). If you get some from an earlier tpi you'll need to cap the 9th injector fitting on the back of the driver's side rail. I'd like to have a set for my tpi stuff I pulled off my IROC....you should be able to get a set for around $50.
87 IROC-Z, 5.7, auto, 3.27, leather, !cat, Holley fpr, K&N'S, SLP 1-3/4" Jet-Hot coated headers, SLP .218/.224 .495/.502 cam, Comp 1.5 roller tip rockers, $uperPITAram, Edelbrock lower intake, Holley 52mm tb, Dynomax\Flowmaster catback. Coming Soon(?)- Fasttrack/Accell DFI
1989 Pontiac 20th Anniversary Turbo Trans Am - 161,000 miles, !cat, 9" K&N
Azrael91966669
25
Jun 20, 2017 04:04 AM
Andrew6.688
Dec 13, 2015 10:59 AM
stalkier
Dec 6, 2015 11:25 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
