350 ticking loder then my headers
Old Jul 13, 2007 | 05:11 PM
Skoda101's Avatar
Car: 1987 GTA
Engine: High reving 332ci monster
Axle/Gears: 3.73 posi
Alright guys I got this ticking sound coming from the passenger side of the motor, it does it really loud when the car is ideling but once above 1k you can barely hear it, It feels like the motor is having a hard time setting at a certain rpm, like something inside the motor is rubbing against some thing its not supposed to.
I tryed to record it today, I believe the best plave to hear it is at 1:40 or 2:40 can't really remeber
"http://www.youtube.com/v/VX1YyIaMY-I"
Old Jul 13, 2007 | 06:00 PM
billydonn's Avatar
Car: 66 c-10 stepside
Transmission: TKO 600
Re: 350 ticking loder then my headers
Are you sure one of the distributor (HEI) wires isn't loose and sparking to the body at the back of he engine?
Old Jul 15, 2007 | 04:38 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Check your plugs. Had one come apart on me and the compression was making it tick tick tick really loud.
Old Jul 15, 2007 | 09:48 PM
Skoda101's Avatar
Car: 1987 GTA
Checked the hei wires, there not grounding out..unfortunitly its never a quick fix the plugs make sence ill give it a go tomorow
Old Jul 17, 2007 | 08:04 AM
Skoda101's Avatar
Car: 1987 GTA
try'd the spark plugs and snesors but nothing... so I decided to pull the oil filter(wait this gets better)... you know see whats up, So it turns out theres metal shavings in it. That metal wasn't there a week ago when I did an oil and filter change...
-So we pulled the motor, and going to have to clean all the oila passages,etc... as for what the ticking was I have my money on a lifter
Old Jul 17, 2007 | 08:30 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
To me it sounds like rockers (lash). But since you've pulled it......
Old Jul 17, 2007 | 05:57 PM
Skoda101's Avatar
Car: 1987 GTA
Viprklr your right but the lash wasn't the only problem along with the locks that had failed........my crane gold rockers are finished, explains the metal in the oil filter (I'll have pics tomorow) Some one's getting a phone call
db057
Sep 4, 2015 07:57 AM
Eric-86sc
Aug 24, 2015 09:01 PM
86iroc z Z28
Aug 21, 2015 10:37 PM
redmaroz
Aug 16, 2015 11:40 PM
mustangman65_79
Aug 7, 2015 09:55 PM
