Need help installing headers
Old Dec 2, 2000 | 11:49 AM
theformula's Avatar
What exactly needs to come off on the passenger side.
And..i noticed there is a heat shield to protect the spark plug wires, underneath the exhaust manifold. Will I re-use this?
Any other tips you can give would be appreciated.
thanks
'92 Formula
305 TPI 5speed
1LE package
Mods: SLP headers,SLP catback,SLP air foil,ported plenum,Crane AFPR (47psi),MSD6AL,AC delco cold plugs, Bosch O2sensor, homemade cold air,K&Ns,3:73s,JET fan switch, Macewen white face gauges
Old Dec 2, 2000 | 06:48 PM
irocz's Avatar
Car: '87 IROC-Z
Engine: 406 Superram/DFI
Transmission: Auto BTE 3000 conv
You'll need to drop the starter and install from the bottom. You won't be reusing the heat shields so you may need a different style of plug wires. Make sure you install that orange heat shielding that came w/ the install kit (you did buy it didn't you?) over the electrical wires (may be diff. on a Formula).
good luck,
87 IROC-Z, 5.7, auto, 3.27, leather, !cat, Holley fpr, K&N'S, SLP 1-3/4" Jet-Hot coated headers, SLP .218/.224 .495/.502 cam, Comp 1.5 roller tip rockers, $uperPITAram, Edelbrock lower intake, Holley 52mm tb, Dynomax\Flowmaster catback. Coming Soon(?)- Fasttrack/Accell DFI
1989 Pontiac 20th Anniversary Turbo Trans Am - 161,000 miles, !cat, 9" K&N
Old Dec 2, 2000 | 09:28 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
I installed mine from the top, but it was a real pain. Here's some tips though. When you have to tighten those hard to reach bolts buy a cheap box wrench for them and grind the walls on it really thin. Also for the plugs, if you have trouble getting them in buy a cheap socket for them that has the hex head on the end and grind the socket just short enough that you can still turn the plug with it.
Good luck.
Riccioli Performance Motorworks
--RPM Racing--
-Currently building first ever engine. 383 with Super Ram plenum and runners, Edelbrock lower intake, Bosch 24# injectors, either AFR or Trick Flow heads, MSD ignition.
-Will be installing Baer Brakes
-Will be installing full Spohn suspension in rear
-Art Carr 700R4 trans??
Old Dec 3, 2000 | 03:08 PM
Scott 88 GTA's Avatar
Car: 88 GTA
Engine: modified L98
Axle/Gears: 3.27 9-bolt
I installed mine from the top as well, the passenger side was the easier one I thought. On the driver's side I just had to unbolt the engine mount and jack it up a little bit. Also, you will definately need to modify your spark plug socket like Paul mentioned, there's no other way to do it.
Black 88 GTA L98
New engine is in!
ZZ4 bottom end, Edelbrock 6085 heads, LT4 HOT cam, GMPP 1.6 RR's, ported stock TPI, SLP 1 3/4" headers, no cat, Dynomax cat-back
E.T.F.A Member #11
Old Dec 3, 2000 | 03:18 PM
86Trans Am's Avatar
I just put my slps in my 86 305 ta, the only thing on my passenger side to take off was the altenator and the heat shields, plus i got rid off all the air stuff. you'll need 90 degree boots on your spark plug wires, you wont reuse the heat shields, the slps will slip in from the top, both mine went in really easy. On the drivers side, i moved two brake lines to the outside of the steering shaft and moved my air conditioner compressor to the side and loosened the power steering pump. And all my spark plugs went in with just a spark plug socket or a box end, i didnt have to modify anything.
remember to be coating the manifold bolts with penetrating a couple days in advance, you dont want to break a bolt off, all mine came out fine. Get yourself a new o2 sensor also.
this was the first real mod i ever did to my car, there are some pics on my site if you need to take a look at them, or email me
1986 Trans Am
305 TPI
"If it's not one thing, it's another!"
http://www2.hanover.edu/hierlmeier
Old Dec 4, 2000 | 06:07 PM
irocz's Avatar
Car: '87 IROC-Z
I got lazy on the spark plug install. Went to sears and bought an 0-ratchet set. plug changes are a snap now.
I did have to use that box end wrench trick for my headers bolts though.
sweet_87_iroc
Sep 25, 2015 10:01 PM
Wesly_66
Aug 26, 2015 09:55 PM
mdtoren
Aug 23, 2015 12:52 PM
theurge
Aug 21, 2015 12:46 PM
drathaar907
Aug 6, 2015 04:20 PM
