What year did HEI stop? Are the 89-92s external coil?
Old Dec 6, 2000 | 06:33 PM
theformula's Avatar
Just wondering this.
92 Formula
305 TPI 5speed
1LE package
Mods: SLP headers,SLP catback,SLP air foil,ported plenum,K&N, Crane AFPR (47psi),MSD6AL, MSD wires, AC DELCO cap/rotor/plugs, Bosch O2sensor, 3:73s,JET fan switch, Macewen white face gauges, Intellitronix Digital Gauges
Old Dec 6, 2000 | 09:43 PM
Tonyrodz's Avatar
Transmission: auto
I know 89-90 are definitely the external coil--not sure about the changeover tho.My 86(tpi) had the hei in it.
Old Dec 6, 2000 | 11:06 PM
black5.7GTA's Avatar
I think 87 was actually the first year for an external coil.
Old Dec 6, 2000 | 11:11 PM
theformula's Avatar
87? The reason Im asking is because IM having a hard time finding spark plug wires.
92 Formula
305 TPI 5speed
1LE package
[This message has been edited by theformula (edited December 06, 2000).]
Old Dec 6, 2000 | 11:28 PM
87Z-ya's Avatar
87 was first year for remote coil hei in f-body. Shouldnt have a problem getting wires. If you have in cap and get remote wires you will just have the coil wire left over.
87z 383,afr 190's, crane hyd roller(224/230-.509/.528,112 sep),Ported and polished mini ram, 30lb inj, 3.42 gears, strange 12 bolt, tremec 5spd, , 1,3/4" slp headers.
[This message has been edited by 87Z-ya (edited December 06, 2000).]
Old Dec 7, 2000 | 08:41 PM
ONEFORMULAOVERALL's Avatar
be a little more informative. i have almost the exact same setup as u so maybe i can help! i'm having a hard time understanding not being able 2 find wires? also did u replace the stock coil? and all distib. after 86 i belive r hei (high energy ignition) just some have the external coil and some inside the cap but all r until 93 don't know after that. let me know!
92 F-BIRd FORMULA T-TOP (WHITEKNIGHT) 5.7L-98,700R4B&MSATURDAY NIGHT
SPECIALTRANS 2500STALL,54MM-AS&M TB-PORTPLENT,LARGETUBRUN,
UNDER PULLEYS K&NCOLD AIR KIT,160THERMO,ELDB HEADERS W/3 1/2 Y PIPE 2 RINO CAT 2 4INCH PIPE 2 FLOW,
MSDDIST,6AL,8MMWIRES.
2BLASTERCOIL.ACCELL PLUGS
CUSTOM FASTCHIP BY ED WRIGHT,AUBERN POSI W/ RICHMOND 3.73 AND SPLINES,TUBE FRAME CONNEC
PST KIT.1LE BRAKE KIT! MANY MORE MODS FORESEEN IN MY ERA!13.38ET @ 109.75MPH
Old Dec 7, 2000 | 09:14 PM
theformula's Avatar
Thanks for the replies. I should of been more specific. I was having a hard time finding MSD wires for my setup. Also they had to be long enough to reach around headers.
I finally found a set. Holley 9mm laser shots.
Getting an MSD coil for christmas.
92 Formula
305 TPI 5speed
1LE package
Old Dec 7, 2000 | 09:17 PM
theformula's Avatar
ONEFORMULAOVERALL, those are pretty good times.
I'm going to be seeing high 13s with my setup now. That is my goal. 13s on a stock motor. Stock cam, heads, manifold,TB,dist.
Whered you hit your 13.3 at?
92 Formula
305 TPI 5speed
1LE package
Old Dec 9, 2000 | 02:34 PM
Thunder Valley, NOBEL,OK
But a day ago i found out that i have the L98 alum. heads with a slight pocket port. stock cam,crank.
Thanks 4 the comp.
Azrael91966669
25
Jun 20, 2017 04:04 AM
aaron7
Exterior Parts Wanted
Aug 18, 2015 05:47 PM
Bryan F
Aug 18, 2015 02:28 PM
midias
Aug 15, 2015 05:07 PM
L98GTA87
Aug 5, 2015 11:02 PM
