Is the TPIS ZZ-9 cam to big for a 305??
Old Dec 13, 2000 | 07:41 PM
david auster's Avatar
Car: 1992 Camaro
Engine: 350 miniram
I am looking into this cam for my 305. I have a full MSD ignition system, 3in Flowmaster catback, (TPIS Big Mouth base, Slp runners, Ported plenum, Those pieces have all been extrude honed.) L98 aluminum heads, and a Slp cold air kit.
I looked at the specs on the cam and I not sure if those lift numbers are with 1.5 rockers or with the 1.6's. I would really like to use a set of those 1.6 Crane Gold Race rollers with my new cam, or would I have to stay with the 1.5's
Old Dec 13, 2000 | 11:00 PM
theformula's Avatar
Stay with 1.5 ratios.
As far as clearance problems , you wont have any going to the ZZ9.
Since you have a lot of mods I say go for it.(the heads being the most significant) I had bought a ZZ9 cam but later sold it because I wanted to keep my intake manifold and heads stock.
91 Formula
305 TPI 5speed
1LE/G92/WS6
Custom cold air intake w/K&N, SLP airfoil, ported plenum, TB coolant bypass,Crane AFPR (47psi),94 octane,Crane Extruded Alum. 1.6 full roller rockers, Timing set from 4*BTDC to 10*BTDC,MSD6AL, Holley 9mm Annihilator Laser shot 50 wires, Ac Delco cap,rotor and plugs, Bosch O2sensor, SLP 1 5/8 headers,SLP catback,3:73s,JET 195* fan switch, Macewen white face gauges, Intellitronix Digital Gauges
Stock throttle body, runners,intake manifold,cam, and heads.
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
