Changed MAF now getting Code 33
Old Jul 19, 2007 | 12:26 AM
TELLEZ's Avatar
I was getting a code 34 on my 88 350 TPI, so I changed the MAF sensor and the code 34 went away, but now I am getting a code 33.
Do I check the voltage of terminal C of the MAF connector with the MAF disconnected or connected with jumper wires?
Any and all suggestions are welcomed and appreciated.
Old Jul 21, 2007 | 03:54 PM
Bustionironi's Avatar
Car: 1985 IROC
Engine: 350HO
Axle/Gears: 10 bolt 3.23 limited slip
Re: Changed MAF now getting Code 33
i have had the maf trouble codes pop up many times. But everytime i get one of those codes it is NOT due to the MAF malfunctioning. I would check the MAF relay located on the driver side of the firewall. It took me a long time to figure out that was the problem so i hope this saves you some time and stress...
chazman
Aug 28, 2018 03:25 PM
Logan Bryant
Aug 27, 2015 11:52 AM
Bert87
Aug 23, 2015 03:50 PM
chazman
Aug 22, 2015 02:01 PM
