TPI Cam question
Old Dec 16, 2000 | 08:47 AM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
TPI Cam question
I'm planning on rebuilding my 89 L98. I would like to use a set of ported aluminum Vette heads, ported upper and lower base, Accel intake runners, and edelbrock headers connected to the 3" exhaust that's already there. My question is whether the stock cam with 1.6 rockers would be adequate for this combo, or would it restrict horsepower? I'm trying to keep the motor fairly stock for gas milage, emissions, drivability, cost, and originality.
I believe the stock cam specs are:
.415"/.430" lift, 206/212 degrees duration, 117.5 LSA
With 1.6 rockers, the lift is about .442"/.458"
Also, can the roller lifters be reused since they don't really wear much?
Old Dec 16, 2000 | 11:41 AM
theformula's Avatar
I think you should go with an aftermarket cam, definitely if your throwing ported vette heads on there.
Do you plan to use forced induction down the road? That is a question you should ask yourself when making your cam decision.
Look at Comp Cams 08-304-8
Crane Cam 2032
Lingenfelter.com cams
TPIS ZZ9.
Whatever you do, don't get too much cam. Especially if you plan on using 1.6rrs.
Just my $.02
Old Dec 16, 2000 | 05:42 PM
Dan87IROC-Z's Avatar
Also look at the GMPP ZZ3/ZZ4 Cam and the LT4 HOT Cam (thats the one I am buying).
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip with 160* Thermostat, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET : 14.32 @ 97.7mph
(corrected for elevation)
Soon to come: LT4 HOT Cam, Air Flow Research 190cc Heads, 2800 RPM Stall Converter and SLP 3.70 Rear End Gears.
gta90
Sep 15, 2015 04:00 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
Sanjay
Aug 12, 2015 03:41 PM
Fronzizzle
Aug 9, 2015 01:15 PM
