Which size injectors do I have?
Old Jul 21, 2007 | 01:25 AM
wildstar's Avatar
Car: 1984 L69 Trans Am
I bought a used TPI system to go into a 350 I am building. The service number on the ECM reads 01227165 so I am assuming this is an 86-89 MAF system.
How do I know whether I have the 19 or 22 lb injectors?
Are the injectors TRULY the only difference between the 305 and 350 systems? Or do they use different Eproms?
In other words, if I have the 305 system, what do I need to convert it to a true 350?
Old Jul 21, 2007 | 07:08 AM
MattODoom's Avatar
Car: '88 G T/A
Axle/Gears: 3.27 9 Bolt
Re: Which size injectors do I have?
Injectors & EPROM are different.
Old Jul 21, 2007 | 11:05 AM
wildstar's Avatar
That's what I suspected. How can I determine which systen I have?
Old Jul 21, 2007 | 11:10 AM
89N10GTA's Avatar
Car: 1989 GTA
Engine: 355 with Super Ram
Axle/Gears: 3.73 10 bolt with a True-trac
i would pull the cover off the eprom and get the numbers. there is a list in tech that should give you an idea of what you have. good luck
Old Jul 21, 2007 | 11:17 AM
89N10GTA's Avatar
Car: 1989 GTA
here try this
http://tpiparts.net/ecms_and_proms/
http://tpiparts.net/305_tpi_to_350_tpi_conversion
http://tpiparts.net/installing_tpi_on_your_vehicle
i hope it helps
92projectcamaro
Jan 18, 2016 08:00 AM
toronto formula
Nov 10, 2015 06:17 AM
Brother Al
Oct 14, 2015 06:39 AM
BAMiller
Sep 14, 2015 06:38 PM
