Need injectors tested and flowed
Old Dec 12, 2000 | 06:09 AM
Roy's Avatar
Roy
Anybody have any reccomendations on where to send them for a reasonable price and decent service?
Thanks,
Roy
Old Dec 12, 2000 | 07:49 AM
cobrakiller1989's Avatar
I just recently asked the same question and I was told to send them to cruizinperformance.
here is the link: http://www.cruzinperformance.com/fuelinj.html
Its only $10 per injector too.
Old Dec 12, 2000 | 09:16 AM
MikeC.86Roc's Avatar
My bosch 24lb. injectors were cleaned and flow tested by Lingenfelter performance. I suspect it is probably more expensive there then at cruzin perf. though..
Old Dec 12, 2000 | 02:25 PM
travsirocz's Avatar
Car: Two 1987 Iroc-Z Z28s
Engine: 5.7 TPI ZZ4 1.6 Roller Alum. Head
Do you have any diesel shops in town. Most places do injector cleaning and balance testing. they might be pretty cheap.
1987 Camaro Iroc-Z Z-28 with a TPI 5.7
-Ram Air,K&N Filterchargers, Gutted Mass
Airflow Sensor, Throttle Body Airfoil,
Edelbrock TES Headers and Y pipe, Gutted
Cat, 3 inch exhaust, Flowmaster
-Hypertech Thermomaster Chip, 160 deg Stat,
Adjustable Fuel Pressure Regulator
set at 50 psi, MSD Cap, MSD 8.5mm wires,
Accel Coil, MSD 6AL Ignition Box, Accel
Plugs
-Richmond 3.73 Gears, B&M Transpak,
B&M Rachet Shifter, Energy Suspension
Products
-Fiberglass Cowl Induction Hood,
Purple Neon License Plate Frame,
16X8 Rims with BFG 245 50's,
Pioneer Deck, 2 JL 12's in a Q-Logic
Box with a 300 Watt amp
What you can put between your ears,
no one can take away.
Old Dec 14, 2000 | 12:25 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I sent a spare set in to Rich (at Cruzin' Performance) a few months ago. I mailed them out from NJ on a Thursday, and got them back from MI on Wednesday! Rich was able to get them to flow within 2% of each other, and he even helped me with a few installation questions.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Dec 23, 2000 | 04:04 PM
Allan's Avatar
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: BW 2.77
Ditto, Rich at cruzinperformace is who'd I recommend. Standard cleaning was $10/injector and he flow matches. He charges $5 per injector replaced to get the best match. (In my case, I had all 8 cleaned and were at 4% flow of eachother, not bad - but he got to 1% by replacing two injectors so he charged me $80+$10 ($5x2 injectors replaced) for a total of $90). I'm not sure if his prices went up, but doubt it. Check him out. Someone posted a link above.
The Camaro Shrine
'88 Camaro IROC-Z 350 TPI
'98 Grand Prix GTP 3.8L SC
"Yea, though I walk through the valley of rice,
I shall fear no Turbo; for Torque art with me."
- Cullan Hooley
Old Dec 23, 2000 | 06:39 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
I got mine done CruizinPerformance, very happy with the job. The NAPA store in Virginia Beach had a shop in back, I had the holes machined in my TPI base to fit my ZZ4 heds. They did injectors, so if you don't want to send them off, check with some of the machine shops/speedshops in your area.
Rob P
89RSconvtZZ4TPI
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Mickeyruder
Sep 2, 2015 02:45 PM
Justin92GTA
Aug 27, 2015 11:16 PM
Keith5
Aug 27, 2015 04:37 PM
Jae992
Aug 27, 2015 09:07 AM
tmellott89
Aug 16, 2015 02:58 PM
