tpi swap
Old Jul 24, 2007 | 09:31 AM
emac2001's Avatar
Car: 86 z28
tpi swap
im getting an awesome deal on an 88 transam 350 tpi motor that i will be dropping in my 86 z28 that is carbed. my question is that i know i will needs a different fuel pump, but i really dont know what psi or anything like that, also what kind of afpr i would need to run. any sugestions, i have never goteen this deep into thigns befoe, but gotta learn sometime. thanks guys
Old Jul 24, 2007 | 07:17 PM
DZcode's Avatar
Car: 1969 Z28
Engine: 406 TPI
Transmission: Tremec TKO 600
Axle/Gears: 3.31
Re: tpi swap
You'll need a high pressure fuel pump.
I used a Walbro 225lph on my 406 with 30# injectors, which is probably overkill. I placed the pump inside a sump-tank that is external to the gas tank. If your 85 has an internal fuel pump, you can swap that out with the high pressure one.
You could probably use a 195lph and be okay if you stay NA. There are formulas on the internet to calculate what you need using displacement, rpm, horsepower, etc.
Make sure you use the proper high pressure hose that is submersible in gasoline, (if you put the pump in the fuel tank) and use high pressure hose to the fuel rail at least 3/8 inch. You can use 5/16 inch return line if you like.
Search the internet. I got all my fuel system ideas on-line.
Your TPI fuel pressure regulator on the fuel rail will work fine (if the engine you're getting is complete.)
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
jharrison5
Aug 19, 2015 05:53 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
