12 ohm injectors
Old Jan 1, 2001 | 01:03 PM
trubo ta john's Avatar
12 ohm injectors
can you run 12 ohm injectors in a 305 or 350 tpi with the stock ecm?
thanks
Old Jan 1, 2001 | 06:33 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
The range I was told is between 14-16 ohms. However, I do not think 12 ohms is that bad if the injectors are designed to operate at that range. The real key is consistancy. All your injectors should be in the 12ohm range.
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
