car will not idle
Old Jul 28, 2007 | 09:03 PM
blue_iroc_z28's Avatar
Car: 1987 pontiac trans am gta
Transmission: 5 speed
Axle/Gears: 3.43 posi
car will not idle
sense i got this car a week ago its taken a long time to turn over, bout 2-3 sec. and it seems to be getting worse. now the car is so hard to start i crank and crank and then when it finally tries to start i have to give it some gas to get it to stay running as long as i keep my foot on the gas it run perfect.it does not take much just the slightest touch keeps it running .if i let it idle MOST of the time it dies or runs so bad it kills its self . can anyone help? i have a lot codes as well.22,24,32,33,34,44,54. all i have is basic hand tools no fancy stuff (volt meters etc.)
Old Jul 29, 2007 | 08:28 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: car will not idle
Looks like your ECM or memcal is taking a dump. IIRC code 54 is an incorrect memcal.
Old Jul 29, 2007 | 08:44 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Okay. All I have are 88 and 92 service manuals so I give you the info from my 88.
22 - TPS circuit low
24 - VSS circuit
32 - EGR circuit
33 - MAF circuit (gm/sec high)
34 - MAF circuit (gm/sec low)
44 - O2 sensor (lean exhaust)
54 - Fuel pump circuit (low voltage)
I don't know of anything that would cause all of those codes to show up at the same time which leads me to believe that it's ECM related.
Before replacing it though you REALLY NEED to get access to a volt meter.
Old Jul 29, 2007 | 08:54 AM
do you think it could be a fuel pump relay? ive heard on here that that could cause a few problems.
specialized
Jun 18, 2022 09:26 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
