good cam for a 355 TPI?
Old Jan 5, 2001 | 09:33 PM
GeneralHazzard's Avatar
what cam would you sugest for a 355 TPI? gotta be able to drive on the street pretty good, but i want it to run on the track GOOD. so more towards performance, but must be streetable without having to pit stop at every gas station along the way.
i was thinking somewhere around 214/224 duration @.050 .443/.465 lift with 112 lobe sep
what do yall recomend?
Old Jan 6, 2001 | 12:32 AM
Dan87IROC-Z's Avatar
Thats hardly any lift for a TPI car, you'll probably want a good .480"+. The LT4 HOT Cam is popular, its only $160 from www.gmpartsdirect.com, thats the one the I bought
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip with 160* Thermostat, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET : 14.32 @ 97.7mph
(corrected for elevation)
Next on the list: LT4 HOT Cam
Old Jan 6, 2001 | 12:37 AM
The specs on that LT4 Cam are 218/228 @ 50 and 492 lift on both sides.
L98 TPI 350 (5.7L)
Old Jan 6, 2001 | 08:43 AM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
General,
Your cam specs sound like a Comp Cams Xtreme Energy 262 flat-tappet grind with a simply a wider LSA. If so, then I have a similar cam in my 305, and like it.
I imagine that your specs are about as far as I'd go with a tuned port configuration, otherwise you'll end up with a cam that makes great power (5500 to 6000) at the point where the TPI gives up.
I had a 2-stroke motorcycle like that once. a 1980 Yamaha RD350LC. It came with some great midrange pipes, and the cylinder had the port raised way up. The pipes came on at 4000, the port came on at 6000, the pipes gave up at 8000, and the port wanted to go to 12,000. As a result, the engine stuttered to 4000 RPM, came alive at 6000,threw the front wheel skyward, then fell flat on its face at 8500 RPM. Very, very peaky and hard to ride.
Um, never mind that last part. Probably not relevant to this thread, but it does illustrate the problems that can happen with mismatched induction, valvetrain, and exhaust.
Daniel Burk
http://www.isthq.com/~dan/fcar.html
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff. PST suspension, Braided stainless brake lines, Koni struts, 11-inch rear disks,Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Turbine Technologies 2500 stall converter, underdrive pulleys, Crane Hi-6 & more.
1.05g skidpad verified.
New best E/T! 14.039 at 100.82 MPH in 41 degree air at Stanton, Michigan.
Old Jan 6, 2001 | 08:48 AM
ws6transam's Avatar
Roger that, Dan. That seems to be a popular cam, when paired to an aftermarket TPI with ported plenum, aftermarket runners, and aftermarket base. Hey, where is your torque converter and steeper gears? Shouldn't you add some 3.42's or 3.73's and a 2500 RPM stall converter before putting in that HOT cam??
Old Jan 6, 2001 | 10:32 AM
bad camaro RS's Avatar
ive got the compucan 2032 and love it still get good gas mileage and pretty good 1/4 times mods and times in sig
1992 camaro RS
373 10 bolt rearend
ssm sfc's
87 350 TPI
bored 30 over
compucam 2032 with 1.6
482-495 LIFT 214-220 duration full roller rockers
msd6AL
1 5/8 headman headers
2 `1/2 flowmaster exuast
k&n filters gutter air box gutted maf
3 pc under drive pulleys
no emissions no egr etc
custom ED Wright chip
eddelbroc intake base and runners ported plenum
midly ported and polished stock heads
Taylor 8mm wires
B&M mega shifter
gutted maf/airbox
hotchkis lower control arms
3" exhuast cutout
homemade cold air intake
2000 tci stall
700R4 with B&M shift kit
new best ET 13.5 @104.66
84z96L31vortec
Aug 20, 2017 12:16 AM
Reddeath210
Oct 6, 2015 08:20 AM
355tpipickup
Aug 13, 2015 07:35 AM
Sanjay
Aug 12, 2015 03:41 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
