Car wont start
Old Jan 7, 2001 | 07:30 PM
aaronb's Avatar
Car wont start
Hey guys, ive got an '85 z28, 305. And the other night i was driving it around trying to charge the battery and it just died. Right before it died it wasnt revving very well, and i also heard a couple of pops coming from up front. I just bought a new battery, and it turns over fine now, but it wont click over. I was thinking about replacing the cap and coil, maybe even the ignition. But the thing is Im a little low on money and Id like to try to save as much money as posible. Can ANYONE help?
Old Jan 7, 2001 | 07:58 PM
MikeC.86Roc's Avatar
When you say it won't click over do you mean the engine just turns over(starter spins and engine turns over) and never tries to fire up? You need to check your voltage at the battery and starter. Also check to see if the plugs are sparking..
Old Jan 7, 2001 | 11:04 PM
aaronb's Avatar
RIght, it turns over but never tried to fire. How do i go about checking the voltage at the starter, and how i know if the plugs are sparking?
Old Jan 8, 2001 | 08:30 AM
Ski89Z28's Avatar
If you have a PEP BOYS around you I would take the alternator off and take it to them to test. They have a machine to test it and it is free!
I tell you this cause I think it is the alternator that is bad. Since you have a new battery it is still strong but it isn't getting a charge so it will soon die.
Good Luck!
Old Jan 8, 2001 | 10:10 PM
aaronb's Avatar
Well, i had the alternator tested and it checked out. Anyone else have any ideas/suggestions?
Old Jan 8, 2001 | 10:24 PM
new87's Avatar
Car: 87Z
Engine: ?
Transmission: A4
HEI modual or pickup coil. The HEI mod is easy to get, but you have to pull the Distributor to get the pickup coil.
87 Z28 305 TPI, Auto, 2.73, Gutted air boxes, K & N fillters, SLP Airfoil, Dyno Max 3" cat back, Accel 8.8 mm spirals, Accel cap and rotor, Accel coil, rapid fires, and 160 Stat.
Best 15.414 @ 87.47.
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
86Base
Aug 8, 2015 01:34 PM
L98GTA87
Aug 5, 2015 11:02 PM
