Could this be do to my injectors?
Old Jul 31, 2007 | 07:20 PM
Cragar87's Avatar
So I've been cleaning out my engine lately because it was terrible looking. Th idiot who owned the car before me did not care for it at all...Anyways today I realized I had a loose connector to the number 6 injector, and I noticed I have three different kinds of injectors.
My car has been bogging down and has had no power, it even has trouble making it to the amazing speed of 20 MPH. Could the different injectors be causing this? It's a long shot but I figured I'd ask.
BTW its a L98 if that matters.
Old Aug 1, 2007 | 12:02 AM
glock's Avatar
Car: 1989 gta
Engine: L98 D1SC procharger twin IC
Re: Could this be do to my injectors?
it could ..but since you have a 350 i think they should be 22lb injectors stock ..to check your injectors ohm them out.... i think 14-18 ohms
Old Aug 1, 2007 | 05:45 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
If they're different they could have different flow rates. If any are higher than you could be washing out that cylinder. If some are too low then you could be running that cylinder lean.
Ohm them. Also get the part numbers off of them and see what you can find out. The ECM only knows what it's been told about the injector size.
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
